wow, id love to see a video.... Im in awe of this project
(and other work you have done)
a few specific questions... I'm trying to figure out the steps needed to do this..., perhaps you could pint me in the direction if I'm missing/misunderstanding something.
a) Keyboard
so your using a doepfer keyboard + controller boards...
so I guess there keyboards which seems to be a fatar + the MKE?
(Im thinking perhaps a desktop module, might be more suitable for me, but still interested how its done... oh, and building a case for a desktop module i think is easier... its just a box
b) knobs/switches
so the knobs/switches come from Musikding.de , then those connected to a USB64 from doepfer
http://www.doepfer.de/usb64.htm
you needed 2 since you have > 64 controls.
I guess you need internally a midi router, to combine the inputs from the 2 USB 64, and the MKE
connecting, USB64 (I've check the manual)
ok, so I see its has 8 banks LP1-8 with 10 connectors,
8 appear to be the input value... and then 2 connects for GND/+5v
you just connector the 8 pots to these GND/+5v and 1-8 ? (and then they are powered from the USB64)
switches seem similar, but you need a 10k resistor , and can only go on inputs 1-16?
(so this implies you have 64 pots or 48 pots + 16 switches?)
its seems the electronic skills required are limited? pins on one end to the board (I guess a GND/+5v rails as needs to go to multiple ports) , the solder directly to pots, and for switches you need to solder the 10k resistor in line.
(I can imagine cable management is fun, with so many pots and switches
c) case
hand built case i guess, and with a front panel front panel , laser cut for you? and then a skin made to the same dimension by someone like
d) power...
I guess the MKE / USB64 all need a separate power supply, of have you combined them...
can it be powered from USB? ... Im thinking an internal USB hub to provide power (to the USB64 and Axoloti) and a single point of access. (I'm assuming if the hub is powered that should be plenty to drive the pots + usb64 + axoloti..
is this broadly correct.... its alot of work, but I'm trying to figure out if I have the skills to do it...
(I've not alot of electronics experience, but think i could solder wires to pots_
anyway, fantastic work... as I said, i see your website and just think 'wow!'
