Hello,
I own the axoloti core for a year or so and haven't had the time to use it much. But the last days I finally finished my enclosure and connected potentiometer and switches to the board. I built an expander board using perf board and used pin head connectors to connect it to the axoloti. Today I uploaded my finished patch and wanted to try it out with my other gear and I realized that the 1/4" audio output does not work. There is a little bit of signal, but it is extremely low, even with the gain on my mixer cranked up. On the other hand is the headphone output working fine. No problems here. So I tried it with other cables, other patches and had a look at almost every setting, but nothing helped. There is/was definitely no short or something. After soldering the parts to the board, I checked everything with a multimeter to see if there are shorts or other issues before powering it up. Does anyone have an idea what the problem could be? Thanks in advance...
