you will need to rebuild the firmware for a discovery board, you cannot just use the axoloti firmware supplied.
before building you will need to change the axoloti defines, and also the memory layout in the ld files.
(the latter you can look at previous versions for reference)
note: this object would work on older firmware... obviously within the memory confines of the board.
