Anyone got an Midi Note to CC Converter
Is there a way to build a Midi Note-to-CC Converter?
Examples:
1) Incomming Midi-Note C2 Channel 1 via USB -> Outgoing Midi CC 44 with Value 27 via DIN
2) Incomming Midi-Note C2# Channel 1 via USB -> Outgoing Midi CC 44 with Value 32 via DIN
Thanks,
Dirk
Yes, you can do that. Have you tried patching something up yourself?
I have tried patching something, but i canĀ“t find objects that will fit my needs. I have to say i am a noob to axoloti, i have only done some basic patchings to get some sounds out of the axoloti.
Can you give me some tips or a general overview what i have to do so i can try to find a solution
and do the patching?
All you need is available in the factory objects. You will find all midi related objects in the /midi/ folder.
Here is my proposal:
Copy this for each combination of midi Note and corresponding midi CC.
If there is a logical relation between the note and the CC value (e.g. (note number)*2 = (CC value)), you can use the other objects in the /midi/ folder to realize this.
Beginner - midi note to float/integer ('select' pure data)
Ok, thanks, I wil try this and post the result.
