Hi!
I'm trying to make an adjustable phasing synth, one saw oscillator is split into two lines with one delayed slightly to cause the phasing.
I've been using the delay/echo but this has a fixed value. How can I make this value adjustable?
Adjustable delay time
mackemint
lokki
look at the delay/read examples, there are interpolated and non interpolated versions.
basically you feed the oscillator to a fixed length buffer which will be your maximum delay, and you can adjust the delaytime by choosing the appropriate starting point in the reader. if you look at the help patches it should be clear.
