So I'm about to do my first modification to my axoloti. I plan on hooking up inputs for an expression pedal and sustain pedal. I'm pretty sure the sustain pedal is straight forward, being just a switch, but I want to make sure about the expression pedal. I have an m-audio EX-P (supposedly this is the Schematic if it helps).
If I solder the leads from the stereo connector to the axoloti, will it be good to go? I have the Getting Started With Axoloti book which says "Any potentiometer with a value between 2.2 kOhm and 47 kOhm with a linear taper" is okay. According to that schematic is has a 12k pot, so maybe it's okay, but there is that low limit pot that's 50k too...
