So this error is seemingly happening for no reason... I have had this patch for quite a while and never had any errors, now all of a sudden the compiler has issues without it, although it has been running without a hitch for several months now.
What it is, i have a switch case to choose between inlets and outlets based on an int select number. Here is the console log of the error
What i find so odd is that this code works! i worked last time i used it on saturday with no issues, the inlet is called inlet_i4.
Here is the once working but now not, code fragment
And the object itself
chain selection.axo (1.3 KB)
Any help is much appreciated as i really have no idea whats happening here, doesn't make any sense, also means i cant run my patch D:
To add to the confusion, this same object runs without any issues inside a different patch
