Hello everyone. I've just finished a new synth after 5 months of work. It's a micro music easel :
This is the sound demo : www.youtube.com/watch?v=w7IrjJ7MmoY
This patch is using only around 40% of DSP load but I can't add any other object without overflowing the Board.
I had a lot of help from many of you especially sirsicksik. this patch took me more than 2 months to develop.
For hardware I've used the Teensy 3.2 to add more analog and digital control, and a MPR121 capacitiv touch sensor for the keyboard. Programming and coding the Teensy was the hardest part for me. Every pin is used...
The 15 faders are soldered to the axoloti, but all other controls are soldered to the Teensy.
About the patch sharing. The patch look really unusable with tones of controls and it's hard to know what you can touch if you don't know it. What I want to do is a final object and share it to the community. But the problem is that I don't know how to make a final liscensed object like all others do to share with the community. I mean I understood with parents parameters how to build the object, but not liscensing and sharing to the library. I need to do it for 3 objects, the wavefolder, the Complex oscillator, and the final object. So if somebody is able to explain me how to do that, I will share the final object with pleasure !
I've made another 15min full tutorial video about all functions of this synth : https://www.youtube.com/watch?v=9uBTyjKZKpg
And I can share with you some pics of the hard soldering time and other building process
