8 step sequencer for noobs
I am still very green when it comes to synth and sequencers etc, and am always looking for new stuff to learn and incorporate into my projects.
With the midi foot controller I have built, I have realized I could very easily use it to control an 8 step sequencer, it will have 2 rows of on/off switches, and 2 rows of adjustable parameters, very similar I guess to this device.. (not including the inputs outputs etc..)
I have watched video about sequencers so I sought of get that each row is for triggering a specific event, and the parameters can adjust the levels of the trigger, and each step is the change in sequence. So I could understand, I can have a sample for each row, each step switched on or off to trigger, with the parameter setting the volume level set for each step.
But what I really want is to learn and understand better how to really use to sequencer, because at the moment, I really struggle to visualize or imagine the variety of ways in which I could use it.
Can anyone recommend any tutorials or video's etc I could use to gain some insight in ways I could use an 8 step sequencer like the one I have described. I have been searching the web the best way I know how, and a lot of it appears to be performance use or lots of in depth patching on a synth, or maybe its just all beyond me.. !!
On a side note, I know from what I have seen that a lot of sequencers are triggered with LFO's and trigger at a fixed rate like a drum machine etc.. but I was thinking less about a fixed rate, but more like the rate of change for each step is triggered manually. This I believe will give more options on what I could with the sequencer ?
It maybe doesnt fall under the 8 steps sequencer category, but some of the best sequencers around that comes in a finished project, in my opinion at least, are Elektron sequencers. Like Digitakt or Octatrack for example.
So if you want some inspiration for sequencer use, check out their tutorials for their products. Read the manuals. They got their famous "P-lock" for example. Which means parameter lock and it means you can assign different parameter values to each step of the sequencer. Which opens up a whole new ball game :slight_smile:
Anyway, check them out, they are really inspiring products when it comes to sequencing :slight_smile:
