As I have mentioned in another post, I have installed Mint Linux, I am a first timer at this after many years under windows, It all installed fine on my prehistoric laptop which I want to dedicate to the Axo.
However now with my tail between my legs I have no idea how to install Axo Gui.
As per the below instructions, I spent all night searching for associations that we help me recognize what I need to do. The only thing I think I can figure out is the instructions refer to Terminal controls.
As this is a seriously noob position to be in, I apologize to anyone that this post may offend.
For anyone who can assist, I will greatly appreciate it. !!!
2.install axoloti runtime
â—¦unpack axo_runtime.*.tgz into user home directory e.g. cd ~ ; tar zxvf axoloti_runtime.tgz
â—¦you will now have a folder ~/axoloti_runtime/platform_linux
3.install application
â—¦install debian package, using sudo dpkg -i axoloti_1.0.deb
â—¦this will install into /opt
â—¦Axoloti app will be on your application menu (may be different on different distros)
4.install dependent packages
â—¦using : sudo apt-get install -y lib32z1 lib32ncurses5 lib32bz2-1.0
5.grant permissions for your user to use the USB device
â—¦make sure the axoloti board is not connected
â—¦run ~/axoloti_runtime/platform_linux/add_udev_rules.sh
