Hi all!
So I recently found some cheap 5W LEDs and a fitting PSU in my local electronic shop.
Then i wanted to try and controll them with my axoloti, I had some patches from the previous smaller LED project and, well... who doesn't want to make the whole room flash in sync with some Oscillators
So this is the basic circuit:
Where IN1-4 are just coming from 4 digital GPIO outputs of the Axoloti.
And it's working really well!
Resistors are 5W, beefy:.jpg?token=oOW4aQXpeNj-eiIVEXJtSg&expires=1541994738&url_token=24xN)
Soldered onto a board and screwed to the bottom of a box, hiding wires within.
.jpg?token=d00k5no-gBStKAQkEy2C5A&expires=1541994864&url_token=BT3L)
You can see the axoloti to the right in another cigar box.
.jpg?token=vDxEif5GYlSZSsLDpdHRgQ&expires=1541995044&url_token=qbAL)
The LEDs I'm using, for now i just let them hang in the air, because they are flashing most of the time they don't really get too hot but I'm planning on putting them on a strip of aluminum.
Forward current: 300-350mA
Forward voltage: 12-13V
Typical voltage: 15-18V
My PSU is a Samsung SB_B221C, which gives you 1100mA @ 16-20,5V but I think basically anything close would work...
I think all in all i cost me about 15€
I'm sorry I can't provide a video but I will follow up shortly.
Cheers!
