#!/usr/bin/python
MHz = 1000000.0
HSE = 8.0 * MHz
pll_m_set = range(2, 63 + 1)
pll_n_set = range(50, 432 + 1)
pll_p_set = (2,4,6,8)
pll_q_set = range(2, 15 + 1)
ahb_presc_set = (1, 2, 4, 8, 16, 64, 128, 256, 512)
def pll_vco_input(hse, pll_m):
return float(hse) / float(pll_m)
def pll(hse, pll_m, pll_n):
return pll_vco_input(hse, pll_m) * float(pll_n)
def pllclk(hse, pll_m, pll_n, pll_p):
return pll(hse, pll_m, pll_n) / float(pll_p)
def pll48ck(hse, pll_m, pll_n, pll_q):
return pll(hse, pll_m, pll_n) / float(pll_q)
def sysclk(hse, pll_m, pll_n, pll_p, ahb_presc):
return pllclk(hse, pll_m, pll_n, pll_p) / float(ahb_presc)
def main():
max_sysclk = 0.0
for pll_m in pll_m_set:
for pll_n in pll_n_set:
for pll_p in pll_p_set:
for pll_q in pll_q_set:
for ahb_presc in ahb_presc_set:
x = pll48ck(HSE, pll_m, pll_n, pll_q)
if x != 48.0 * MHz:
continue
x = pll_vco_input(HSE, pll_m)
if x < 1.0 * MHz or x > 2.0 * MHz:
continue
x = pll(HSE, pll_m, pll_n)
if x < 100.0 * MHz or x > 432.0 * MHz:
continue
x = sysclk(HSE, pll_m, pll_n, pll_p, ahb_presc)
if x > 180.0 * MHz:
continue
if x >= max_sysclk:
print('sysclk %d pll_m %d pll_n %d pll_p %d pll_q %d ahb_presc %d' % (x, pll_m, pll_n, pll_p, pll_q, ahb_presc))
max_sysclk = x
main()
Gives:
sysclk 72000000 pll_m 4 pll_n 72 pll_p 2 pll_q 3 ahb_presc 1
sysclk 96000000 pll_m 4 pll_n 96 pll_p 2 pll_q 4 ahb_presc 1
sysclk 120000000 pll_m 4 pll_n 120 pll_p 2 pll_q 5 ahb_presc 1
sysclk 144000000 pll_m 4 pll_n 144 pll_p 2 pll_q 6 ahb_presc 1
sysclk 168000000 pll_m 4 pll_n 168 pll_p 2 pll_q 7 ahb_presc 1
sysclk 168000000 pll_m 5 pll_n 210 pll_p 2 pll_q 7 ahb_presc 1
sysclk 168000000 pll_m 6 pll_n 252 pll_p 2 pll_q 7 ahb_presc 1
sysclk 168000000 pll_m 7 pll_n 294 pll_p 2 pll_q 7 ahb_presc 1
sysclk 168000000 pll_m 8 pll_n 336 pll_p 2 pll_q 7 ahb_presc 1
So - yeah. No solutions for 180.0 MHz
