Scopes that shows more than 128 samples. For example 256, 512, 1024, etc.
An idea for bigger scopes could be:
The scope could have a drop down menu like the tables have, where you chose tablesize. The scope then display the amount of samples that is set in the drop down menu. This wold be really awesome, cause if you set the scope display size to the same size as the table you are using, you would then be able to see the whole content of a table.
