This is both a request for a few new versions of some all ready existing objects and a request for a fix for a few existing objects:
sel/sel i 16, sel/sel i 32:
Would be really great with values from 0-127 & -64 to +64 instead of 0-99. In relation to all other objects that you might want to control from the sel/sel it 16 would make more sense to have 128 step instead of 99. I tried using math to convert the 99 steps into 128 but it doesn’t work very well. There will be rounding so it will skip some values.
Also it would be really nice to be able to use all sequencers from a subpath parent. A lot of them are accesable when you use them from a parent, but for example:
sel/sel fb 16
sel/sel fb 32
sel/sel fp 16
sel/sel fp 32
sel/sel i 16
sel/sel i 32
… i think are not added in the right way when trying to make them "parameter on parent". It will only add each step at a time, not the whole lane. And they will be added in a vertical fashion, one by one, not like they probably should be; whole lanes, horizontally, from left to right. If I remember correct some of the most regular sequencers has this issue in the first version of Axoloti and have been fixed.. But a few of the not so common used sequencers still has that issue.
A few longer version would also be most welcome of the above mentioned sequencers. Like 64 and 128 steps. That would be really awesome.
