Why isn't the granulator working?
incomplete object reference attribute in granulator_1
Generate code complete
Start compiling patch
BDIR = /Users/xe1ex/Documents/axoloti/build
FIRMWARE = .
RM
APP
! /Users/xe1ex/Documents/axoloti/build/xpatch.h.gch
. /Users/xe1ex/Documents/axoloti/axoloti-factory/objects/osc/brds/brds_digital.h
. /Users/xe1ex/Documents/axoloti/axoloti-factory/objects/osc/brds/brds_analog.h
/Users/xe1ex/Documents/axoloti/build/xpatch.cpp: In member function 'void rootc::instancegranulator__1::dsp(bool, bool, int32_t, int32_t, int32_t, int32_t (&)[16], int32_t&)':
/Users/xe1ex/Documents/axoloti/build/xpatch.cpp:684:59: error: 'class rootc' has no member named 'instance_i'
int table_index = _USAT(inletposition,27)>>(27-parent->instance_i.LENGTHPOW);
/Users/xe1ex/Documents/axoloti/build/xpatch.cpp:726:26: error: 'class rootc' has no member named 'instance_i'
int32_t y1 = parent->instance_i.array[table_index&parent->instance_i.LENGTHMASK]<instance_i.GAIN;
/Users/xe1ex/Documents/axoloti/build/xpatch.cpp:726:63: error: 'class rootc' has no member named 'instance_i'
/Users/xe1ex/Documents/axoloti/build/xpatch.cpp:726:95: error: 'class rootc' has no member named 'instance_i'
/Users/xe1ex/Documents/axoloti/build/xpatch.cpp:727:29: error: 'class rootc' has no member named 'instance_i'
int32_t y2 = parent->instance_i.array[(table_index+1)&parent->instance_i.LENGTHMASK]<instance_i.GAIN;
/Users/xe1ex/Documents/axoloti/build/xpatch.cpp:727:70: error: 'class rootc' has no member named 'instance_i'
/Users/xe1ex/Documents/axoloti/build/xpatch.cpp:727:102: error: 'class rootc' has no member named 'instance_i'
make: *** [/Users/xe1ex/Documents/axoloti/build/xpatch.bin] Error 1
any ideas why it might not be going through?
There is an object in your patch, "granulator_1", that expects a (named) reference to another object. I guess it is a js/granulator object, this object needs a reference to the name of a table in the "table" attribute.
