Why do i get timeout errors on this patch?
KrautSynth_0.6.axp (66.7 KB)
Do you get a time out error as well? It might be a problem on my end, but if you ahve the time, please load the patch and check.
If I remove the chorus object right before the audio out stereo, i get no errors.
Can't generate MIDI output
Just tried your patch, and it worked on my setup, even with the chorus object. (using 1.0.9)
So I really don't know what's wrong on your side.
What does the console say ?
Cant remember what it says now, but one problem might be that i use my midi controller not directly plugged in, but through reaper (a DAW). That might cause weird things.
I'll leave reaper out and see what goes one. Thanks for checking!
