I'm loving the axoloti - my live rig is now pretty much based around it, using a bank tables and buttons to scroll through pre-designed patches.
However, I'm having an issue around the wave/play objects. When I switch away from a patch that has played a .wav from the SD card, the axoloti crashes. I've had to rescue this by cycling power. The funny thing is, as long as no sample has been played in the patch (i.e. if the triggers have been muted), the switch occurs fine, but it crashes even if the samples playing have all finished.
Can anyone explain further to me what this might be about? Does anyone else have the same problem, and if so is there a workaround?
