Here is the error I get when trying to compile a patch containing the @toneburst sinesyc
oscillator in 1.0.8-28-g5b96816-dirty
Any ideas?
Thanks
Generate code complete
Start creating directory on sdcard : /VOSIM
creating dir: /VOSIM
Done creating directory
Changing working directory on sdcard : /VOSIM
Axoloti says: file error: FR_NOT_ENABLED, filename:"/VOSIM"
Change working directory: /VOSIM
Start compiling patch
Compiling patch... with /home/gabriel/axoloti/firmware
BDIR = /home/gabriel/axoloti/build
FIRMWARE = .
RM
rm -f /home/gabriel/axoloti/build/xpatch.o /home/gabriel/axoloti/build/xpatch.elf /home/gabriel/axoloti/build/xpatch.bin /home/gabriel/axoloti/build/xpatch.d /home/gabriel/axoloti/build/xpatch.map /home/gabriel/axoloti/build/xpatch.lst
APP
arm-none-eabi-g++ -nostdlib -fno-exceptions -fno-rtti -mcpu=cortex-m4 -O3 -fomit-frame-pointer -falign-functions=16 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -Wunused-parameter -DCORTEX_USE_FPU=TRUE -DTHUMB_PRESENT -mno-thumb-interwork -DTHUMB_NO_INTERWORKING -mthumb -DTHUMB -std=c++11 -DARM_MATH_CM4 -D__FPU_PRESENT -H -I/home/gabriel/axoloti/CMSIS/Include -I/home/gabriel/axoloti/chibios/os/ports/common/ARMCMx/CMSIS/include -I/home/gabriel/axoloti/chibios/os/ports/common/ARMCMx -I/home/gabriel/axoloti/chibios/os/ports/GCC/ARMCMx -I/home/gabriel/axoloti/chibios/os/ports/GCC/ARMCMx/STM32F4xx -I/home/gabriel/axoloti/chibios/os/kernel/include -I/home/gabriel/axoloti/chibios/os/hal/include -I/home/gabriel/axoloti/chibios/os/hal/platforms/STM32F4xx -I/home/gabriel/axoloti/chibios/os/hal/platforms/STM32 -I/home/gabriel/axoloti/chibios/os/hal/platforms/STM32/GPIOv2 -I/home/gabriel/axoloti/chibios/os/hal/platforms/STM32/I2Cv1 -I/home/gabriel/axoloti/chibios/os/hal/platforms/STM32/OTGv1 -I/home/gabriel/axoloti/chibios/os/hal/platforms/STM32/RTCv2 -I/home/gabriel/axoloti/chibios/os/hal/platforms/STM32/SPIv1 -I/home/gabriel/axoloti/chibios/os/hal/platforms/STM32/TIMv1 -I/home/gabriel/axoloti/chibios/os/hal/platforms/STM32/USARTv1 -I/home/gabriel/axoloti/chibios/boards/ST_STM32F4_DISCOVERY -I/home/gabriel/axoloti/chibios/ext/fatfs/src -I. -I/home/gabriel/axoloti/chibios -Winvalid-pch -MD -MP --include /home/gabriel/axoloti/build/xpatch.h -c /home/gabriel/axoloti/build/xpatch.cpp -o /home/gabriel/axoloti/build/xpatch.o
! /home/gabriel/axoloti/build/xpatch.h.gch
/home/gabriel/axoloti/build/xpatch.cpp:214:3: error: expected unqualified-id before 'public'
public: void Init(rootc * _parent) {
/home/gabriel/axoloti/build/xpatch.cpp: In member function 'void rootc::Init()':
/home/gabriel/axoloti/build/xpatch.cpp:743:26: error: 'class rootc::instancesinesync__1' has no member named 'Init'
instancesinesync__1_i.Init(this );
Makefile.patch:58: recipe for target '/home/gabriel/axoloti/build/xpatch.bin' failed
make: *** [/home/gabriel/axoloti/build/xpatch.bin] Error 1
Compiling patch failed ( /home/gabriel/axoloti/patches/VOSIM.axp )
