Anyone know if this is possible with Axolotl?
http://bagger288.com/goldenmaster/vosim-synthesis-for-the-masses/25
It looks very simple, but doesn't seem to be possible with Factory objects (requires s-rate VCA).
It is "almost" possible to create the VOSIM algorithm. I have a semi-working patch, but before posting it I would like to know two things:
1) is there is a way of getting a saw oscillator which is a decaying one, not a rising one.
I can create one by setting the cheap saw oscillator, then set a constant to 64 and subtract from this the output of the saw, but the constant is a green output and when connecting it to the math/- object the green cable is a dashed line. It seems to work, but I do not know if this is the correct way of doing this.
2) How does the phase red input of the osc/sine oscillator work? I mean what value triggers the phase?
Edit: I realised that I want to use a sync'ed sine oscillator but the toneburst/sinesync object does not compiles on 1.0.8.
