Using external audio in for sidechain compression
Is there a good compressor object that accepts sidechain input so I can compress my Axoloti output using external audio in as a sidechain input?
Sure, this is my subpatch for a sidechain input. Replace the keyb_1 object with whatever you want to use as a side chain trigger, I'm using a note 37 on MIDI channel 10.
The output of the object goes into a math/* with the signal to be compressed on the other input. :slight_smile:
KickEnv.axs (2.9 KB)
edit. check:
sss/dyn/compressorSC
