Hello,
i am just thinking of what I wanna do later:
Put in an audio source, maybe audio input or a wave file from sd card, then I want to split up the stereo signal into left and right, now I want to manipulate each channel individually, for first try I simply want to add a phaselag of maybe 90°.
Is this easily possible, right now I think so, but I have to try later, amybe someone has already some expirience with that.
I did try once to do 2 sinus oscilators with phase lag, I did not find anything useful back then.
The reason why I am asking, I want to look at the corresponding signal in XY mode of my oscilloscope, and that does only work properly when there are different signals on the left and right channel and phaselag also helps to make the picture move, so I wanna experiment with that.
Thanks a lot.
