Hi there,
I have a simple question.
Which is the right way (step by step) to save/upload a patch to the axoloti (sd) in order to play it standalone?
Thank you for now!
Upload patches problems
lotwenzel
jaffasplaffa
If you just want to upload a single patch to axoloti you can do that by:
1. Open the patch.
2. Go do drop down menu "patch".
3. Select "upload ot sd-card as startup".
4. You now have a single stand alone Axoloti instrument
If you want to upload more patches, you could try the "patch bank" system, which you can find info about by searching. Or start from this thread:
I cant help you with the specifics on using a patch bank, since I havent used that myself.
But the single patch is really simple to do.
