Updating the convolution filter
I made a patch like the granular convolver. It uses the graintable object to feed the convolution table.
I have a dial controlling the position of the grain table and as I turn it the change speed object turns on the recording of the convolution table.
grainconv.axp (6.3 KB)
This does result in an initial clicking when the change is happening.
I was wondering if anyone had any ideas how I could make the change of sample smoother?
i did not look at your patch, have you tried a smooth object between the dial and the object inlet?
