Universal pitch knob for selectable osc
Hey all,
I am building a Minilogue clone as my first project and have run into what I am sure is a newbie problem. I have 2 osc with a radio control for selectable waveforms and need a knob that can pitch all the waves at once so I don't have to adjust each individual waves pitch. Can this be done with some of the utility objects?
Thanks!
The dial on the left is connected to both oscillators and controls pitch of both osc's. I think that would do it?
and if you want to move the dial (not the inlet) you can create a modsource with the modsource object and use that to control all 4 (or more) dials.
@jaffasplaffa I need to also send note data with a midi keyboard I don't think the dial would work.
try this:
@lokki That was it. Thank you all!
note, that if you set the dial on the mix object to 12 you will get an exact octave of pitch modulation (if an lfo is connected for example) this is where axoloti and its numbering system really shines!
