Hey!
I was playing around with loading regular samples into a table/read and playing them them back but came across an issue regarding playback speed and pitch. Using table/read is good for wavetables, like on the picture I have posted... But this set up does not work very well for regular longer samples, cause pitch and speed are both being controlled by the phasor oscillator. Position works fine on longer samples too, but the pitch and speed would be really nice to use independent of each other.
Sooo.... is there a way to make speed and pitch independent of each other when using table/read or table/Read interp?
Thanks
Will test it. Thanks
