Hey friends,
wondering what the best method is to control poly subpatch parameters via CC or NRPN. would i rather have the midi input in the subpatch, or have it in the main patch and route to the subpatch via an inlet? whats the benefits of each version?
Subpatches: patch inlets vs. input objects in the sub patch
weasel79
jaffasplaffa
If you have the midi stuff in the polyphonic subpatch and you set it to 7 voices you use 7 of every midi objects that you use.
If you have them outside nd route inside via inlet, it uses less cpu/memory.
But to be honest not sure what would be the best functional wise but cpu/memory wise having it outside is the best solution.
weasel79
Yeah thanks those were exactly the thoughts i was having.. but i also vaguely remember reading that subpatch i/o as well as parameter remote control via the patcher object cc mapping is quite heavy on resources?
