LFO :
Sine
Saw
Square
Sample&Hold
Sync input
LFO_multi.axs (5.2 KB)
samplehod_k_cheap.axo (992 Bytes)
UPDATE new version , because the S&H module was using about 10% . The new S&H module operates at k-rate and reduced load to about 3%
LFO :
Sine
Saw
Square
Sample&Hold
Sync input
Hey
Thank you for the lfo.
Was just playing around with this lfo and updated it a little bit and thought I might share it.
LFOMM.axs (7.7 KB)
Edit, updated second time. There was a few issues but it is now working as intended.
The updates:
I have added a separate sync input for the sample & hold lfo... but it is still possible to use the Sq lfo as input for the sample & hold. You do that on the button in down right corner. I also added a modulation input for the the modulation amount. That means you can set another lfo to modulated the amount that this lfo sends out
Alex, btw when I opened the subpatch I noticed that 2 of the 3 lfos had one value and the third one had another value. They should probably all have the same value. Or else when you change from one lfo to another it will have different speeds. I also updated that in the new one.
Cool Will try that out
Also the new one I added had another problem with the modulation input. I updated it. Now it is working as supposed.
