Any ideas how to get this to work?
SPI/I2C OLED display
probably remove the resistor at the spi location and bridge the connection at the iic location...
I actually tried it. I also same time added the bridge between R8.
How to wire? I wired like this:
GND: power ground --> GND
VCC: --> VDD
D0: CLK clock (sdk/scl k) --> PB8
D1: MOSI data (sda) --> PB9
RST: reset --> VDD
DC: data/command --> GND
CS: chip select signal --> GND
But the screen stays black.
The SSD1309 is compatible with the SSD1306.
This 2"42 OLED needs to be modified for I2C : remove a resistor, add three straps, connect the DC pin to zero for @0x3C or 3v3 for @0x3D...
The RES (reset) pin is more tricky and i had to experiment quite a lot before having something on the screen.
At the moment i use a little RC circuit so that the OLED display resets automatically on power up... but i think it needs some more experimentation to say if it is reliable enough. (without this RC the OLED does not work)
VDD
| | 10k
+----------+-------->Res pin
----- 68nF | | 100k
GND GND
Here are a 2.42" a 0.96" and a 1.3" displays.
What should a standard metal enclosure look like?
I'm working on an object that will allow to display 8 lines of 21 characters...
Work in progress...
Is it possible to have a oled screen working with knobs so that when knob is turned the screen shows the value and string for the knob automatically, so it wouldn't need to have any buttons pushed. And after like 15sec when no knob is touched oled would show scope.
You can do that in the patch with objects -- knob turn to send a trig to the object to switch to that string and then a timer to switch back to "main" string page display.
I'm away from the patcher, sorry I don't have any more detailed object names
Hey just a quick question about these connections. Did you just solder wires onto the Axocontrol board pins that were already soldered or are you running you wires from the axoloti pins underneath?
Can I show midi clock pulse on Oled somehow? Maybe just a blinking pixel on corner or something
just use the period "." for example. i did something like this. you will need a string mux, one input with an empty string, the other with the period. connect the midiclock output to the mux in via a pulselength object, so you can adjust how long the point is lit. i also made some concatenate objects for strings, so you can still display other things on that line.
as a sidenote, it will be more precise and easier to just have a tempo LED....
Anyone have any more precise tips how to do this:
"Is it possible to have a oled screen working with knobs so that when knob is turned the screen shows the value and string for the knob automatically, so it wouldn't need to have any buttons pushed. And after like 15sec when no knob is touched oled would show scope."
"You can do that in the patch with objects -- knob turn to send a trig to the object to switch to that string and then a timer to switch back to "main" string page display."
Hey i know i had this working before but i am currently egtting these errors on compiling in a very empty project... any idea @SmashedTransistors?
! /Users/blndr/Documents/axoloti/build/xpatch.h.gch
. /Users/blndr/Documents/axoloti/axoloti-contrib/objects/tiar/HW/tiar_font5x8.h
/Users/blndr/Documents/axoloti/build/xpatch.cpp: In member function 'void rootc::instanceOLED128x64__1::calcScopePage(int, uint8t*)':
/Users/blndr/Documents/axoloti/build/xpatch.cpp:340:27: error: 'class rootc' has no member named 'instance_i'
uint16_t y = ((parent->instance_i.t[i]+64)*3 )/8;
/Users/blndr/Documents/axoloti/build/xpatch.cpp: In member function 'void rootc::instanceOLED128x64__1::sendTextPage(int)':
/Users/blndr/Documents/axoloti/build/xpatch.cpp:388:21: error: 'class rootc' has no member named 'instance_i'
tY[i]=((parent->instance_i.t[i]+64)*3 )>>3;
make: *** [/Users/blndr/Documents/axoloti/build/xpatch.bin] Error 1
edit: nevermind. apparently this was because i had no tiar scope present in the project.
all working fine as expected from one of the GOATs, @SmashedTransistors
Hey @SmashedTransistors what do you think is a maximum realistic amount of OLED on one I2C line? i have some that can jumper-select adresses 0x3c/0x3d and some with 0x78/0x7a, if i change the aderesses in your object these should work right? or would this even work with one of these i2c expanders/multiplexers?
also does anybody have experience with adding several SPI devices? can i just use other GPIO digital pins as additional CS/SS pins for the same MOSI/MISO/SCLK?
