NEW MODULE
"qtsLFO"
four tempo synced sine LFO's with multiply, divide and octave tempo and phase offset control (internal and external)
NEW MODULE
"qtsLFO"
trying to make a new control system to enable multiple parameter control with just 4 knobs and a couple of buttons
Check this Modular thing controller subpatch. It has got two layers, put is is pretty easy to expand. And it works properly, with "soft take over". But making som dedicated objects with hook etc. would be awesome, and probably more DSP friendly.
my modules automatically update the right way. if you switch over to another destination, it updates the knob to the newly chosen location.
now I'm building-in preset-ability and I'm thinking about adding a function generator, though that last piece could get it a bit too complex/big for the simplicity I want..
also, as you can select which instance is the receiver, you can add up to 32 receivers.. that's 32*8 controls
(though you could change that in the code to even more receivers)
Not sure I understand that. The patch I made, has got hellcores hookmod, which works with GPIOs. The regular hook object doesnt, only works with dials. The knob only takes over when you turn the button to the setting you set to it before you switched to the other layer.
Probably same way yours work.
but anyway, the way your patch could use this module is to be able to control anything with the joystick or whatever knob you choose, using buttons to switch between receiving modules and selecting outputs
I think I'll just build a new one from your objects if you put them in here sometime.
But yeah, good idea to keep the joysticks destinations "open". You mean joystick can be assigned to any destination that the other knobs are assigned to?
you can connect any control to any parameter, so you can make a controller for your synthesizer with lots of different styles of controls and you just use the one you like for that parameter..
Sounds pretty interesting
Would be awesome with an example patch for these, how to set it up etc.
Btw, do you have some kind of smoothing for the GPIOS inputs implemented into the objects?
Or does that have to be added with an "external object"?
I haven't used those inputs, it's more of a general routing module. so that's where your module comes in
or maybe it's an idea to combine the modules once it's finished?
Yeah, first I think I just need to try the ones you have made and understand how they work , I guess
And then find the best combination
NEW MODULES
PATCH
"sendMatrix"
"receiveMatrix"
"dispMatrix"
the first is a module to write the controller value to a table or to get it's value to the controller when another destination/preset/output is being selected
Can be controlled by GPIOS controls using the CV input and button-inputs to walk through the menu
the receiveMatrix reads from the table and outputs 8 signals per module. A selector is used to select which instance it is. (this could even be manually controllable if you want, such as to switch control-values between groups of parameters)
the dispMatrix is a quick way to show which destinations are being selected.
NOTE though, that when two controls select the same destination, the destination will get the valuefrom the last module in the direction of the code. (eg most-right module)
My axocontrol objects have a low pass filter on the analogue inputs. So you could combine mine and sss to get what you want.
I figured offloading the dial management to an arduino would allow me to do more with my axoloti.
I have endless rotary encoders up dating a number of variables on the arduino. Which send via midi if they change. It does mean I am going to have a lot of cc receive objects in my patch tho.
Thanks, Ill look into it
The one I got is all ready works pretty well, but always up to trying different options. Especially for saving some DSP
NEW MODULES
NOISE
"noiseOsc"
noise generator that updates at the rate of the internal phase
a 12dbLP/12dBHP bandpass filter then filters the generated noise
both pitch and cutoff are controllable
MATH
"expCurveA" and "expCurveK"
audio rate and control rate stackable exponential curve generators build from a for-loop of ___SMMUL functions, with the exp parameter mixing between multiplying with a fixed value(no change) and multiplying with it self (curving) . The result will probably not be an exact exponential curve, but at least it's kinda cpu low and able to give a exponential-like curve to certain signals (envelopes for example)
"bipAmp"
bipolar attenuator of incoming signal
NEW MODULE
OSC
"bassOsc"
variation on the trisaw with added sine-ringmodulation to add resonance peaks and a bit more control/modulation options
