Simple way to pitch down input?
Hello folks.
Sorry about the noob question but i want to use the Axoloti to do a simple 100-200% Pitch down of the audio input. I tried the fx/clds/Pitch Shifter but it just distorts the signal. Any tips or patches that could help me here?
Thank you!
Don't think there's a good solution for this yet with the standard objects.
There is a pitch shifter object in the community library (sss/fx/pitchshifter), but I don't have any idea on how to use it since it doesn't come with a help patch.
Ok finally I found the solution to my pitch shifting problem using fx/clds/pitchshifter . I let a programmer friend look over the code and he found a little bug that can be resolved by changing one line of code in the module.
When you open fx/clds/pitchshifter.axo in any editor, search for the line "fx.Process(iobuf,sizeof(iobuf));" and change it to "fx.Process(iobuf,BUFSIZE);" then save it. The Pitcher works like a charm now :wink:
thanks, fixed in factory
Nice! :+1: Thanks! Told my friend to write to the github file but you were half an hour faster :wink: have a nice night!
I always wondered what was wrong with that object! Sounds like is a overlap add, is that correct? If so, couldn't it be used also to shifting up the pitch?
It could, but it wouldn't sound very good.
Why?
(AH, 20 characters rule...)
Just as a general rule of thumb with cheap stretching algorithms, your result will only sound good if it's lower-pitched than if you sped up the sound (pitch and tempo). In my experience with real-time granular pitch shifting, shifting it up as far as an octave will introduce some really nasty distortion in the mids. I don't know how octaver guitar pedals work, but I don't think this object works like that.
