Short Convolution (Guitar Cabinet Modeling)
#21
can you share your cab impulses? or a link?
#22
@lokki
I got a bunch from this site, though I havent converted any of them to "Axoloti format" yet:
http://www.grgr.de/index.html#ir
Just let the site load. It start out with scrolling far down a site in a bit odd manner. Just let it scroll and you will get to the cab files. The ones I have checked are all random sizes, so they probably have to be stretched individually.
Also this site:
#23
I would like to know:
1. How much is the algorithmic latency? (That is, if the impulse response were an undelayed dirac pulse, which delay value for a [delay/echo] would be equivalent?)
2. Does it only work with 16-bit resolution for the impulse response?
Thanks in advance!
#24
  1. The current implementation has 2 samples algorithmic latency
  2. Yes, it works only with a 16 bit impulse response. The internal accumulator is 64 bit though. 32-bit resolution requires a different implementation, and would load the processor much more. I do believe that a this is an acceptable compromise in most cases.
#25
Sorry to bring up an old thread but I'm very confused as to how you can convert a impulse response in wav format into an axoloti table.
Can someone please explain this?
Thanks
