@chaocrator
Just tried a sound dump that I have used in Pure Data, which worked, but didn't work from Axoloti, neither via midi cable or USB:
240, 62, 19, 0, 16, 127, 0, 1, 64, 64, 64, 66, 96, 0, 0, 24, 127, 1, 64, 0, 0, 0, 0, 0,
64, 64, 64, 66, 96, 0, 0, 0, 127, 3, 64, 0, 0, 0, 0, 0, 52, 64, 64, 66, 96, 0, 0, 0, 127, 5,
64, 0, 0, 0, 0, 0, 0, 2, 64, 0, 0, 0, 0, 0, 20, 0, 0, 0, 76, 59, 127, 127, 127, 0, 0, 0, 64,
0, 0, 0, 0, 1, 0, 0, 0, 107, 64, 31, 0, 0, 0, 0, 0, 64, 64, 64, 1, 64, 0, 0, 64, 1, 64, 0, 2,
40, 64, 55, 0, 0, 0, 0, 0, 64, 64, 64, 0, 64, 0, 0, 64, 3, 64, 0, 0, 3, 0, 0, 127, 64, 5, 64,
0, 0, 0, 1, 0, 20, 64, 64, 0, 127, 127, 127, 127, 127, 127, 127, 127, 127, 127, 8, 0, 53, 64,
100, 0, 64, 100, 0, 100, 110, 0, 15, 64, 127, 127, 0, 127, 64, 0, 0, 0, 0, 64, 0, 0, 64, 0, 0,
0, 64, 0, 0, 0, 0, 64, 0, 0, 64, 0, 0, 101, 64, 0, 0, 0, 0, 64, 0, 0, 64, 1, 0, 64, 0, 0, 127,
37, 5, 0, 127, 0, 0, 0, 0, 64, 0, 10, 127, 60, 9, 0, 127, 0, 0, 0, 0, 64, 0, 0, 64, 127, 61,
64, 64, 64, 0, 0, 0, 64, 0, 0, 64, 64, 64, 64, 64, 64, 0, 0, 1, 0, 0, 0, 64, 0, 0, 0, 64, 0,
0, 0, 64, 0, 0, 0, 64, 6, 1, 114, 8, 0, 90, 0, 0, 64, 0, 0, 64, 0, 0, 64, 0, 0, 64, 0, 0, 64,
0, 0, 64, 0, 0, 64, 0, 0, 64, 0, 0, 64, 0, 0, 64, 0, 0, 64, 0, 0, 64, 0, 0, 64, 0, 0, 64, 16,
100, 0, 0, 15, 8, 5, 0, 0, 0, 1, 12, 0, 0, 15, 0, 0, 55, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4,
4, 4, 4, 4, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 0, 0, 0, 75,
105, 99, 107, 32, 32, 32, 32, 32, 32, 32, 32, 32, 32, 32, 32, 0, 0, 0, 0, 21, 247
Anyway, so didn't work in first try, as it did with a parameter value. Maybe its because it's a lot more data send at once, as you mentioned. Do you have a suggestion for sending it slower or in chunks, maybe?
I know blofeld can handle it, as I have been using it with PD for a while.
Going to see if there is something I can tweak in the axo editor.
Thank you for the object, btwm it was a great starting point
