I've ordered a slightly quicker sdhc I'll try...
SD card and sensel morph
Could it be something to do with the filename? I'm not familiar with 8.3 but I'm pretty certain I didn't save the patch to the card in 8.3.
Steps forward...
I've got it loading a patch and keeping the morph connected - I can now load a patch in flash and change it by enterring the card. Next step is patch changng, which I've begun but so far failed - as a start point Im trying to use the buttons on the axo to switch patches... more trying/searching later...
I should have also asked about what version of Axoloti firmaware/Axoloti patcher you're using?
Updating now, or at least trying to - nothing seems particularly easy in axoloti. Its a great device but getting it where you want is more a PITA than I'm used to or expected.
you don't have to
takes some getting used to; but this forum and users can help.
This post is getting long but maybe it's just a case of some planning ahead:
* patch change
* what "produces" the change
* if using USB MIDI - patches have to address this
Just a few ideas from top of my head...
At this point I'm not sure I have the right firmware in my axoloti core? It's showing as:
Authentic Axoloti Core
Firmware version: 1.0.0.1
Software wise I'm: Axoloti version : 1.0.12-2-0-g7975cc87 build time : 29/11/2018 14:38:54 CET
I'm perhaps wrongly assuming the versions should match?
Meanwhile I can change patches and presets, but am yet to figure out controller objects. I've things to try but I'm partway down a frustrating rabbit hole... it's quite the hackaround. I assumed it was my rubbish computer skills but am reassured by someone who has the skills that for the most part it's not elegant.
sorry had to leave..
yeah, all good, Im on the same firmware/Axoloti Patcher (editor)
ohh plenty of posts/info around...
This might help?
Thanks that's helpful - I think the problem I have is that can't seem to get a controller object to run on a blank patch. I've added a directory:
local controllers C:\Users\Andy\Documents\axoloti\objects\
checked the enable controllers and saved a test file that runs when I make it live in normal use, but nothing.
I've got a friend on the case so hopefully he cracks it...
??? why this?
The so called "controller object" is just a patch with the patch change mechanism...(and its directory) if this makes sense to you.
this is my patch = patchchangeall.axs
allows MIDI program change and use of the two tiny buttons on Axoloti itself
this file/patch "reside" similar to your C:\Users\Andy\Documents\axoloti\objects\
correction: dir should be: C:\Users\Andy\Documents\axoloti\objects\controllers
Thanks for the help.
The blank patch was just to see if the test patch I made was compiled into it - wasnt though. I'll try with that extension...
Yes, your software and firmware are the best stable versions.
Here's what I see on startup:
Axoloti version : 1.0.12-2-0-g7975cc87 build time : 09/04/2018 13:15:31 GMT
Link to firmware CRC E95BAC96
Status: factory (1.0.12,anon) : OK ( 1.0.12,clean )
Status : home : OK
Status: community (1.0.12,anon) : OK ( 1.0.12,clean )
USB device found
connected
search path : /Users/me/Documents/axoloti/axoloti-factory/objects
Firmware version: 1.0.0.1, crc=0xE95BAC96, entrypoint=0x20011000
search path : /Users/me/Documents/axoloti/axoloti-local/objects
search path : /Users/me/Documents/axoloti/axoloti-contrib/objects
finished loading objects
Update time...
I used keyman's patch in both versions of the MPE patches - I have patch loading from sd, buttons switching between two patches and he morph playing nicely, hurrah!
Today's job is to add in a preset select patch a friend passed on, and then get the patch select into a controller object - currently its not loading the file path though I've been given a clue as to why (file extension apparantly - its not recognising the ones given here as it should do, but seems it might if I remove the users\andy\axoloti part).
Ultimately though I'm where I wanted to be and now I'm trying to get set up a little better so I can take things further... Thanks for all the help folks!
Slight error in post above: removing 'objects' from the file path worked for my friend.
It isnt working for me though - can't seem to get loading controller objects working at all, despite apparantly pointing it in the right place i get:
Using controller object: controllers\changepatch
Unable to created controller for : controllers\changepatch
