Replacing radio object with row of buttons + midi feedback
I want to replace a radio object with a row of buttons on my midi controller. The row goes up chromatically, so getting out the integer value I want to have is no problem.
I'm struggling now with the midi feedback. I want only the the button coresponding to the selceted value to light up.
This is what I got so far:
I got no reaction, no midi feedback what I don't really get.
Oh and I tried different midi out objects that's why I have note and notehold.
Ah got. Ah toggle with delayed pulse on the set was the solution.
I find the midi out object really confusing. Isn't a midi note message only note value + velocity (and velocity >0 on and <0 off?) I thought that the trigger was just to tell the object somehting happened but it seems to have the function of the velocity. Isn't that a bit double?
P.S. And apparently you should not feed the velo output 64, it didn't work, it should have 1.
