Hello,
I'd like to have several objects each one listening to a different MIDI CC input and each one with a ditferent MIDI channel. Can't find this. The MID/in/cc is listening to all channel, is there a way to add a channel selection?
Thanks
Receiving MIDI CC on selected channel
berzelius
lokki
create a subpatch and set it so it has a midi selector, you can then choose your midi channel from the top patch.
toneburst
It's also relatively easy to add a MIDI channel selector to the factory keyb object, if you fancy digging into the object code.
a|x
