Radio button name on subpatch
Hi, i try to create a subpatch
in this subpatch i have a radio button (4), when i use this sub into a patch, i have no indication on the 4 radio.
the text/comment is not visibile... is right?
how can i put some text nearby the radio?
Edit: i have 2 version of my sub patch in the component search but only one in the file system (i have deleted the oldest)... there is a cache somewhere?
thanks
When you create a radio button, there will be a test label on the left top corner of the object. Usually named i_1, i_2, and so on. Double click this label to change the text.
Adding text for the individual radio buttons is not possible at this moment.
uh, very simple thanks!
uhm, no I_1 is the name of the group of the radio not the single...
there is another button type to make a select? I want to do soomething like this.
it will be useful a radiobutton with images (for the waveform)
most of the demo patches put a comment next to them, this works as the spacing of inlets and comment height is the same. not ideal but works ok for now
yeah, this is a bit of an issue... and its in the bug database.
for now, always make sure you use edit instance on subpatch (in the parent patch) (i.e. don't load it from the file menu)
Ok, someone can look if i'm in the right way?
thanks smile
FM_multiosc.axs (4.7 KB)
