Question about pitch bend
Quick question: How do I make a patch that can receive pitch bend? I have some that will bend and others that will not and I cannot figure out the device(s) that enable the bend. I am actually planning to use it on the linnstrument but I am asking for both regular patches and MPE ones as well.
Big thanks to the axo community!
Fly-Bry
You'll need a keyboard and a pitch bend object. Best is to feed the pitch bend through a math/*c object before adding it to the note signal of the keyboard. Setting the math/*c object to 12.00 will give you a full octave bend below and above the played note. This will work with a regular keyboard. Can't give you advice on MPE since I don't own a device. Patch and screenshot below.
axo-pitch-bend.axp (3.7 KB)
Thanks so much! That makes sense. I will reprogram a few patches tonight.
MPE object has a pitch outlet that includes pitchbend. ( and a note outlet which does not )
That closes the circle! Muchas gracias tb
