here:
note: Johannes, create the 'voice patch' first, as he shows it monophonic, then he saves it, and loads it into what becomes the main patch.
this was also before embedded patches, with an embedded patch, you do the same, just you do have to worry about saving the voice patch to disk, and then ensuring you put it all in the sub-directory - so much easier.
btw: if you are using an embedded patch, after you make a change, make sure you hit the update button.
anyway, try with an embedded voice, and if its still not working post it here.
(thats the other advantage of embedded patches, you only end up with one file to share
yeah, Ive got to stop playing with Axoloti for long enough, that I can make some more videos/music.
