Polyphony question... passing voices through midi
Hello everyone...
I am still very new to the community and have a few questions. first off is there a manual anywhere that I just totally missed because that would be helpful. second I'm trying to figure out if what I'd like to do is possible. I would like to create a 3 voice polyphonic patch, voice 1 will go out through dac 2 and audio out left, voice 2 through dac 2 and audio left and voice 3 will get passed out through midi. would I want 3 mono with bypass subpatches? I'm not sure...
the 'manual' is online
https://sebiik.github.io/community.axoloti.com.backup/c/user-guide
also, Id recommend you look at the tutorial patches, and the help patches, they contain alot of useful information
so you want
V1 - > audio out left
V2 - > audio out right (i assume typo in your desc as otherwise its just both to audio left)
V3 -> midi output.
easy enough, you just need to use patch/polyindex
then conditionally you can sent to audio/out/left right or midi/out
bare in mind audio outputs are summed across voices, so you can output zero on the audio outs for voices that dont contribute to the audio.
I'm having trouble understanding how I can use the polyindex to route as I said.
I figured out how to use a demux wikth the patch/polyindex object to route the the subpatch out of left or right which works great. I'm still working on figuring out how to essentially bypass the subpatch for voice 3 and just route out the midi data. I didn't understand what you mean by the audio outputs are summed across voices but things seem to be working fine. I haven't tried DAC outs which will be used for triggers, gates envelopes etc. (I'm still waiting for parts in the mail)
