Polyphonic Sampler Patch
I want to share my Sample Patch. I call it Sampelotte.
I hope you enjoy.
Over.axp (43.1 KB)
Under.axp (20.8 KB)
Yoroshiku onegai shimasu !
Interesting. Do you have some sort of description of the concept behind it? Sure, we can look at the patch, but it would be interesting to hear your reasoning behind the analog (potentiometer) inputs for instance.
I made a short video on youtube. in a realy bad quality, because i do not have fancy video equipment.
It is a 8 voice sampler, where you can record a sample an habe this one sample pitched over the entire keybard.
there is an ADSR for cutoff, amplification and pitch. there is only one ADSR and it can be switched with a switch. than there is a simple saw/sinus oszilator for tunig the samples pitch and also for sound creation.
The sampled are looped and start of the sample and the loopspeed can be adjusted. I think thats is. the is a (hidden) LFO. it only can be used with MIDI stuff.
Hi, I’m a musician an I’m really interested to create something like that, is there any way that you share the things to build it ? Thanks in advance
It is not too complicated. load the batches above. Than you have to solder a lot of potentiometers to analog inputs. Yout can change the input in the patch or solder it like in the patch. and than you connect a midi keyboard to the midi input of the axoloti. I edit the batch a bit, because the pitch and cutoff envelop switch does not work realy well. if you have any questions, ask me. good look
OverSimple.axp (31.3 KB)
