Polyphonic controller using RAW samples?
Hi
First post here, been tying to make a polyphonic sample machine
Everything works in mono, but poly doesn't seem to work here.
It works if I replace the table with a saw or any other objects in the sub-patch.
Do I need to add something to the table in the sub-patch maybe? See attached for patch
I'm a total noob here, and help is most appreciated!
polysampler1.axp (4.1 KB)
There is a mellotron patch in the community library (abhoth/AxoBlock/Mellotron) which is a polyphonic sample player. It's not perfect, but it works. It might give you an idea.
