Hey guys,
this is work in progress and kind of messy but i though maybe someone has fun looking at this and pointing out some obvious mistakes i am making...
here's the main patch, i limited polyphony to 3 for developement, in the end i might have to split my 6 voice polyphony to 3 axoloti boards due to CPU limitations.
and here's the voice patch. couple issues.
what i am trying to achieve is a 3 OSC synth with several diffferent osc models per oscillator, similar to eg. the waldorf quantum. you can switch from VA waves, to sample layers, to physical modeling or FM oscillators.
the loop play and looping functions work but aren't fully implemented or even patched yet. the alternate output of the oscillator muxers is in "experimental stage"...
also i am still pretty uneducated on exectution order, iirc its left to right then up/down so i tried ordering the objects in a way that seemed to make sense to me. all wrong?
everything is working quite nicely so far but i am sure there is a lot of things that could be done more efficiently and/or elegant. so please advise here...
