Playing long audio file
Is it possible to play long audio files from sdcard...? For instance a 5 minutes .wav file. If it is possible how could I achive it?
Thanks!
It is possible, and quite simple, but the object is not absolutly stable (it sometimes just stops reading), but I'm sure it's something to do with the SD card itself.
You need to have your file in RAW format, and then use the object wave/play fn (stereo)
Thank you! I am going to experiment.
