ok i see what is going on.
if you open the patch the +- object will be in red, because axoloti cannot find the object (because philoop referenced his own local copy in the patch instead of the community one).
so, just click on the black triangle of the object and replace it with phi/math/-+i that should get you working...(also you may have to adjust the number in it afterwards, 22 from the screenshot)
