I found a reverb on the forum but without a dry/wet. Can anyone explain how to patch a dry/wet? I know how to patch one in max msp but am unable to open it for some reason..
Thanks
Thanks
Something like this should work. Replace the TSG/dist/diodeSat with the reverb with no mix wet/dry function and use the wet/dry dial to set your mix:
I love the jaffa/mix/xfade3 as it is stereo and uses a "constant energy" mixing scheme.
