Hello,
I have installed the Axoloti Patcher software (Windows10 Pro v1709, Java 9.04). Works so well. But if I want to save a patch, the program crashes without a message.
When I call the preference and click Select, the program crashes.
You can't work with the patcher like that.
Does an SD card have to be installed for the Patcher to work properly?
I hope I could explain my problems understandably.
Or does the patcher have to be unlocked?
With kind regards
tangram
Patcher crashed when i want to save a patch
tangram
this is caused by an old JRE...
this can be fixed as described here:
background: the issue is, we bundled a copy of the JRE with the patcher, so that the user did not have to start installing java , and so we know everyone uses the same version (so has same behaviour) - unfortunately it appears one of the Windows 10 releases has broken this version. When the next version of axoloti is released , it will come with the newer version of the JRE and so resolve this issue. However, Im not sure when this is planned for.
tangram
Thank you for your answer. That was the solution. now everything works right.
Thanks for the help,
Greeting tangram
