After creating my first patching and fiddling around with it, i decided to close it and then reopen it later. I then got this message... And my patch is lost. No biggie, but I still spend a couple of hours on it. Can it be restored somehow?
Javax.xml.stream.XMLStreamException: ParseError at [row,col]:[109,10]
Message: XML document structures must start and end within the same entity.
javax.xml.stream.XMLStreamException: ParseError at [row,col]:[109,10]
at com.sun.org.apache.xerces.internal.impl.XMLStreamReaderImpl.next(XMLStreamReaderImpl.java:596)
at com.sun.xml.internal.stream.XMLEventReaderImpl.nextEvent(XMLEventReaderImpl.java:83)
at org.simpleframework.xml.stream.StreamReader.read(StreamReader.java:110)
at org.simpleframework.xml.stream.StreamReader.next(StreamReader.java:94)
at org.simpleframework.xml.stream.StreamReader.peek(StreamReader.java:77)
at org.simpleframework.xml.stream.NodeReader.readElement(NodeReader.java:142)
at org.simpleframework.xml.stream.InputElement.getNext(InputElement.java:233)
at org.simpleframework.xml.core.CompositeInlineList.read(CompositeInlineList.java:172)
at org.simpleframework.xml.core.CompositeInlineList.read(CompositeInlineList.java:144)
at org.simpleframework.xml.core.CompositeListUnion.readElement(CompositeListUnion.java:189)
at org.simpleframework.xml.core.CompositeListUnion.read(CompositeListUnion.java:162)
at org.simpleframework.xml.core.Variable$Adapter.read(Variable.java:482)
at org.simpleframework.xml.core.Composite.readVariable(Composite.java:613)
at org.simpleframework.xml.core.Composite.readInstance(Composite.java:573)
at org.simpleframework.xml.core.Composite.readUnion(Composite.java:549)
at org.simpleframework.xml.core.Composite.readElement(Composite.java:532)
at org.simpleframework.xml.core.Composite.readElements(Composite.java:445)
at org.simpleframework.xml.core.Composite.access$400(Composite.java:59)
at org.simpleframework.xml.core.Composite$Builder.read(Composite.java:1383)
at org.simpleframework.xml.core.Composite.read(Composite.java:201)
at org.simpleframework.xml.core.Composite.read(Composite.java:148)
at axoloti.PatchGUI.OpenPatchInvisible(PatchGUI.java:1029)
at axoloti.PatchGUI.OpenPatch(PatchGUI.java:1042)
at axoloti.FileUtils.Open(FileUtils.java:149)
at axoloti.menus.FileMenu.jMenuOpenActionPerformed(FileMenu.java:251)
at axoloti.menus.FileMenu.access$200(FileMenu.java:49)
at axoloti.menus.FileMenu$3.actionPerformed(FileMenu.java:105)
at com.apple.laf.ScreenMenuItem.actionPerformed(ScreenMenuItem.java:125)
at java.awt.MenuItem.processActionEvent(MenuItem.java:669)
at java.awt.MenuItem.processEvent(MenuItem.java:628)
at java.awt.MenuComponent.dispatchEventImpl(MenuComponent.java:351)
at java.awt.MenuComponent.dispatchEvent(MenuComponent.java:339)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:761)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
