Hello,
do anyone know how i can set the coefficients of the object filter/fir16?
thanks
Gunnar
Hello,
thanks
Gunnar
The coef input uses one buffer (16 samples) as coefficients.
You can use "other/bufferindex" + "table/read" to scan a table at buffer rate.
Use "disp/scope buffer" to visualize the coefficients.
thank you very much for you advice. Its very interessting and exciting for me to check the theory behind FIR with a tool like axoloti.
Designing (FIR but also other) filter coefficients can be anywhere between easy and complex. Doing filter coefficient design explicitly in a patch is a bit weird. I hope to have an integrated filter coefficient design wizard in Axoloti one day, but this is very low priority...
i start study again
http://ptgmedia.pearsoncmg.com/images/9780137027415/samplepages/0137027419.pdf
so many things lost over the time.
