Note length interceptor
Hi!
I’m interested in intercepting midi keyboard inputs and changing how long Key’s are held down for in my patch.
I know how to get the gate input from a midi keyboard, but I don’t know how I’d fake a longer / shorter key press... is it possible?
ok, so midi only has gate, no concept of how long the note is.
but you could do what you want ;
if you want to shorten the note: (or rather set a maximum length)
you could do this, by from note on, starting a timer (/delay) and using that to do the noteoff (/gate) after the specified 'timeout' if the note has not already finished.
if you want to extend the note: (or set a minimum length)
basically you do something similar, but this time the note_off, is ignored if its before the timer, , and you use the timer to turn the noteoff.
if you just want to always have the same length note, you can simply use a timer and ignore the note_off.
