No "./voice" module
#21
ok I figured that one out myself, had too many voices, not enough memory in DSP to do that patch at 8 voices i guess. Probably need to do some trimming on it
#22
have a look a using precious resources for tips.
It might be useful for others and also for us (to help improve user guide) to know what you found confusing...
or how it could be explained better. (was there anything 'misleading' ?)
was there something unclear in the user-guide, or something we could improve in the tutorial...
(also Johannes put some videos on youtube)
initial impressions are often really valuable, since once we get used to a piece of software, our familiarity makes certain steps/processes 'obvious' , which are not obvious to the beginner at all smile
a tip here, which you probably know now... the search window will always show you your subpatch if its found it, if will show the 'closest' match... so hitting enter will give you the wrong object.
(the search is not only doing by name but also descriptions, ordered by closer matches first... so possibly synth is in the demux description, if you type synth)
